Best OS for 2009 Macbook Pro?
bigboy529
Pretoria
Hi all
I'm helping a friend who has a late 2009 13 MacBook Pro, 2 GB RAM, 256 GB hard drive, can't remember the processor spec, it's still running OSX 10.7 Lion.
As is, the machine still works perfectly for her needs which is basically web browsing, listening to music, watching movies and light photo editing, so upgrading the components won't be necessary. The techie in me want to update the OS though and I'm wondering how new I can go. El Cap is still officially supported, but I personally never liked it, plus I'm sure it will be stretching the limits of this machine. I'm thinking more towards going with 10.8 or 10.9, anyone with personal experience running a older MacBook Pro on one of those or even newer? Personally I liked 10.10 quite a lot, I found it very solid, but it also might be somewhat of a stretch.
The processor is probably the Core 2 Duo. I'd double the RAM to the officially supported 4gb, replace the HDD with a low end SDD, and install El Cap. If it doesnt work install 10.10.
For what it's worth, these can handle more than the official number for RAM. The 2008 didn't handle 8GB (some chipset issue) but it was rock solid with 6GB. The 2009 may be able to use 8GB. This, combined with the SSD, will make it handle most daily stuff quite well.
