Shannon88
My SO got us an awesome little bread machine recently. Whilst I have gotten my paws on quite a few recipes already, I was just wondering if any of you have any "go to" recipes I should try?
Bread maker/Bread machine... AKA, Mini oven on steroids I supposeBread machine? Is that some hipster name for an oven?
Ours is a Platinum. Haven't had a chance to try it yet, but am going to this weekend.Which model did you get - we have had the go to Panasonic for years and it still sets the benchmark.
It's like a mini oven with a dough hook inside it. You put in the ingredients and it mixes and bakes and 3 hours later you get bread.Bread maker/Bread machine... AKA, Mini oven on steroids I suppose![]()
The manual has recipesOurs is a Platinum. Haven't had a chance to try it yet, but am going to this weekend.
Dankie Smurfie, will have a squizz at it.
Please Urbz, you're still too young to be putting a bun in the ovenHipster name for a wife I think
Ours also has the setting for the lightness of the crust. Will set it on light for the first loaf and see what happens.We've had a Russell Hobbs for the last 6 years, inherited from our emigrating daughter. I'd start with one of the recipes from the manual and later on you can start experimenting. Ours has settings for lightness of crust (we use light otherwise it's a bit crusty) and size of loaf (ours has 3 weights for the loaf we make most often).
Thank you so much! Will give it a whirl on the weekendSuggest medium for first test. Also - look for the basic recipe that has butter in it and use that as your first one.
If you cannot find a recipe like that - here is one for a large loaf that works well. Pu the ingredients into the machine in the order I list them below.
1 and a 1/2 teaspoons dry yeast
450gr white bread flower (suggest Eureka Mills)
1 teaspoon sugar
1 teaspoon salt
2 tablespoons milk powder
2 tablespoons butter
320ml filtered water
Set for basic loaf, large size and medium crust. Think the baking cycle for this one is around 4 hours.
Thank you for all the advice. I think this is going to boil down to a case of trial and error, to see what works best with our machine.The addition of butter / oil IIRC prevents the bread from going stale too quickly. Sugar is for activating the yeast, it needs to work quickly in order to let the bread rise within the 3-hour programme, it's not enough time for the yeast to actually break down the starch in the flour.
w.r.t. the water - tap water will probably work fine, but the chlorination isn't great for the yeast. I use spring water when I bake.
IIRC, when we used a bread machine, I always put light crust. YMMV, I guess this is a matter of personal preference.
Fortunately with bread, it is pretty hard to get it so wrong that it's inedible.Thank you for all the advice. I think this is going to boil down to a case of trial and error, to see what works best with our machine.
