Best small business anti virus programs
oldBastard
Strand
So as the heading states what is the best/reasonable cheap antivirus for a small business company, so far max 10 users? Trend, Symantec, AVG, etc?
I know AVG is a bit expensive, but what would be the going rate be?
I used Kaspersky and was very impressed.... Around R135/Year I think?
Avira Antivir.
Last extensive report on AV I saw it came top of the list. Also not as heavy as some of this other AVs you get.
I'd also recommend NOD32, works well, low memory usage, updates files are small it it uses less bandwidth (cap), also if you pc's are networked you can setup a LAN mirror, so only one pc downloads the updates and the rest of the pc's get the updates of that pc.
For a 10 user license it will cost around R 2,919
You can download a trial version Here
