Hi,
So since we are not so secure with Eskom and can have multiple consecutive hours of load shedding, what the best solution?
Battery opperated lights with solar panels?
Inverters?
Generators?
It was a non commie country that gave us enronomicsMove to a non-commie country..
How do you hook it up?For now I would say buy a battery backup system, for just your lights,tv and for urgent pc usage.
3kw system with 4 x Ritar 12v100Ah sealed lead acid batteries.
Budget 15k.
Deep Cycle lead acid yes, but I love my Lead Crystal batters, they can take a punishment of going down to any voltage and recover all the time.For now I would say buy a battery backup system, for just your lights,tv and for urgent pc usage.
Budget 15k.
I think gel batteries are actually the best solution.Deep Cycle lead acid yes, but I love my Lead Crystal batters, they can take a punishment of going down to any voltage and recover all the time.
No one buys lead acid anymore, and if budget allows go Lithium Ion instead.
I haven't experimented with Gels, just Lead Crystal and the white paper statistics look bloody good, been using them for around 5 or 6 years nowI think gel batteries are actually the best solution.
My home system with a 3kw inverter and 4 x (gel) lead acid batteries is running smoothly since 2014.I haven't experimented with Gels, just Lead Crystal and the white paper statistics look bloody good, been using them for around 5 or 6 years now
Directly to the db ... you won’t even know that the council cut off the power.How do you hook it up?
Wow that is good to hear. Just don't let a lead acid drop to a low voltage. I have heard they don't like it but I am speaking of what I have heard and not experienced. But you are right on the inverter, they do shut down at a certain low voltage. I think that is what is keeping your batteries happy. (just my 2 cents input)My home system with a 3kw inverter and 4 x (gel) lead acid batteries is running smoothly since 2014.
I then had about 10 more systems installed for my friends and family members , but used Ritar batteries and also going smoothly since 2015.
Nothing wrong with lead acid batteries if they being charged properly.
Not sure why you guys carrying on about deep cycle when the inverter shuts off anyway at 70% (battery) DOD, unless that’s what you mean by deep cycle ?
Only negative thing about this setup is you need to know which plugs are connected to the circuit that is backed up. You wouldn’t want to connect a heater or vacuum and drain those batteries quickly.
My electrician charges no more than 3k to do the install. That price is including parts.Quotes I got on this was pretty rough. Entailed getting a CoC and such. Didn't make it viable for me as a temporary measure. Temporary in that we're likely moving within the next six months.
Budget 15k.
He didn't say anything about panels? Battery backup. Not solar.Uh no, not at that price.
300w panel is still in the R1700 range. Panel cost alone would be R17k for 3KW.
You've probably got a Lead Acid is also crap.
Please could you share your electrician's details? Looking to install a battery backup system asap.My electrician charges no more than 3k to do the install. That price is including parts.
He’s quite fair and people like him are rare. But generally in business this is common, more chancers than anything .
