Billion Help PLEASE!!
terencevs
I just did something so stupid! I upgraded my billion 5102 with the 5102s firmware!!! No no links etc want to work! Can some1 please tell me what the link is to the firmware upgrade section on the billion router itself.
Its not in my browsers cache!
If the webadmin page does not work properly then you have probably "bricked" (killed) it :(.
the webadmin does work but none of the links are there. the links that are in history I can browse but the firmware upgrade link is not there. If i can get that link and then do the upgrade with the right firmware it should fix it!
I fixed it.
Telnet to the router and type "sys romreset" and it restored to the old rom with defualt settings.
terencevs said:
I fixed it.
Lucky you :).
Firmware upgrade
Hi Guys
Just remember when you upgrade the 5102 or 5102s remember to do a hard reset i.e. the reset button at the back, hold it for +- 10sec and it will sort out the problem. Sorry for the late reply was away for well deserved R&R.
