Billion N73x MWEB help
Musiclover08
South Africa
I recently purchased a Billion N73x router with the MWEB branding. However, coming from another Billion router, I cannot change the SSID, disconnect the ADSL via the interface nor access any menu whatsoever. It has something called EZSO, which is fine and dandy but I want to access the advanced parts of the router. Does anyone know how I can go about doing this?
Well first that is the Easy Sign On, try browsing to the IP that was assigned to the router or default 192.168.1.254 and log in.
There will be "advanced" option when you click on it go to WAN and boom you will have the settings your heart desires.
The EZSO is only for first time users that need to phone MWEB to configure the router.
I also have one and it is for once a good Billion router.
The other option is to click on advanced if you can access the router and navigate to the menu for WAN settings etc, it will be the last option if i can remember correctly.
The manual for the router http://www.billion.com/support/download/usermanual/usermanual.html
