Bottled water vs tap water reagent tests
Jan
Who's the Boss?
Staff member
The Rabbit Hole
We compared bottled water with tap water — with surprising results
MyBroadband performed reagent tests on popular bottled water brands and tap water which revealed that there is no significant difference.
Bottled water has become popular in South Africa, partly because people believe it is much cleaner than the water you get from your taps at home.
Still.. you would not start or maintain a sour dough starter from tap (or use metal utensils). Even when you are making vinegar / kombucha.
edit: @Snyper564 how is creating beer from tap?
My biggest concern is uranium (specifically in parts of Joburg near old mine tailings).
The strips do not test for any bacteria, though. This means the reagent test used in this experiment is not a conclusive test on whether water is safe to drink.
Bacteria would be my biggest concern.
After the taps running dry here in PE come December.
Bit of a BS test and statement, try testing the water out taps from Witbank, Hibberdene and an old town in the Karoo somewhere.
But didn't you get a jojo with the previous rounds of "we'd wait for rain to solve our water"?
I’ve been accumulating tanks. 12kl of storage at the moment but it’s not currently potable so when water shedding hits us it might become an issue.
There are a few options:
1. You can let the tap water rest in an open vessel for 24 hours to off-gas the chlorine.
2. You can boil the tap water to off-gas the chlorine
3. (recommended) You can add potassium metabisulfite to remove both the chlorine and chloramine.
No chlorine in tap water? Isn't that a bad thing? Must be full of bacteria and amoebas.
made from premium oxygen and heliums?
Hydrogens
But some premium water is prepared water, over the years I’ve found two that I prefer over the others, so much so that I won’t drink other bottled water.
Avian, I’ve only had a few times but in every water test I’ve seen, avian still ranks on top.
Hydrogens
a friend of mine has a water bottle cooler thing and that water tastes nice, his wife is quite anal about the water she buys
but at the same time I'm addicted to my fridge water that comes from my tap, after my first sip I will have two glasses after, especially at night- maybe its the tik in the water I don't know
