I'm still struggling to get this bridge working... any in-detail instructions on setting this up??
What exactly can't you get working? All it requires is that you check the PPPoE Relay box under ISP settings. Then you should be able to dial a second connection from your PC (this is set up from Windows Network Connections).
... My bad. Typo in the password. lol
Its working now.
Now how do I configure Vista64 to only use the PPPoE connection? Should I use something like Routesentry? both are international.
