Business Analysr vs Systems Analyst
Bernie
What is the difference between these two job descriptions. What do they actually do. For every google page I find, I find a different interpretation, some of it understandable some of it quite cryptic.
So, what is your interpretation of these jobs. Any BA's or SA's here - what do you do?
Thanks.
BA - responsible for defining the business processes (eg flow of delegation, authorization, business requirments) required to accomplish an objective.
Will interpret the specification from a customers point of view. Mainly provide a high level overview of the system requirements.
SA - will define the technical aspects (eg. tools / methodology) to used to accomplish an objective. Will design technical specification of the project with the developer in mind. SA will usually also be a developer or will work closely with them.
My 2 cents....
My 2 cents....
+1
Also be aware that some companies confuse this definition. My own included :p
My 2 cents....
good definition.
I do mostly BA stuff at work.
Also called an IT analyst.
