YoungRedNed
- Mar 9, 2013
Hi Guys an Girls (PC Correct)
I am looking for factual information, not smart ar*se uninformed replies from those who cannot resist seeing their name in print. I have a Ford Laser 1.4 1991 which up to last February had an standard Lead Acid battery. This battery lasted about 4 years before it failed. My local supplier replaced the original lead-acid battery with an Calcium battery.
After a few weeks I notice the Calcium battery was slowly losing its charge. I recharged the battery but after a week or so it again began to lose its charge. I had the Battery tested and was told 'Car charge rate = 13.6 volts. New 'battery not holding a load'. A replacement Calcium battery was fitted
A few weeks later the 'new' battery had again discharged to the point where it could hardly turn the engine over. Another evaluations showed the no-load current drain with only the alarm system and the car clock running was 120mA (0.12amp). The charging voltage on fast tick-over was 14.1v. I use this car every day with few exceptions.
As I write, the battery is in need of another recharge. None of my original lead-acid batteries used since 1991 needed to be externally recharged while in use.
Anyone had a similar experience with Calcium batteries? I'm told lead-acid batteries are no-longer made!
