Cape Town Based Fibre
Relentle55
I've returned to the online gaming scene and enjoying it. The part I don't like is the high latency to EU servers. Latency is key, so I was thinking that I could improve that by not connecting via Johannesburg which I believe adds 40ms or so onto the system.
Which is currently best for gaming from CT?
heya, are you physically located in CT? (just checking because you're mentioning JHB?) ; CPT based ISPs would primarly used West coast cables to get to EU ; and as you mentioned, do end up having better latency to EU.
Atomic is a good boutique ISP (no first hand experience, just sentiment I've picked up on the forum - they use good international peering partners)
CoolIdeas is usually your go-to mainstream ISP for gaming - just because you can give them specifics and they do make an effort to try optimise routing/latency etc.
gl hf
