After almost getting stuck again due to a flat battery, I am trying to find a suitable battery disconnect switch to reduce the current drain when the car is not being used. I would prefer a switch which does not require cutting the current battery leads. I can't seem to find anything like this locally at Midas or Autozone etc. (see pics) ...
http://www.google.com/imgres?q=batt...73&start=10&ndsp=15&ved=1t:429,r:2,s:10,i:110
http://www.amazon.com/BATTERY-CUTOFF-SWITCH-BOAT-RACECAR/dp/B001HSBW74
http://diy.twenga.co.uk/battery-disconnect-switch.html
Any suggestions for a cheap reliable trickle charger would also be appreciated.
