OK,Salt River
I go to the one in Milnerton for the last 6yrs,. no problems so far but then again nothing like what you have had
OK,Salt River
Decat means taking off the catalytic converter on your exhaust. You would've known if it was clogged as it would make a knocking sound.By the way, he also said my catalytic converter was clogged up, so he had to 'decat it'. I literally have no idea wtf that even means.
But it didn't solve ****.
They should not have just taken it off as that will affect a lot in modern cars
He just took out the catalytic converter without informing you first or asking?Did not hear any knocking sound, but he assured me it was clogged up...
What can happen?? He said we don't have emissions laws like they do in Europe, so wasn't necessary.
Actually what you're describing can happen, the ecu can get wrong readings and try adjust to the missing readingDid not hear any knocking sound, but he assured me it was clogged up...
There is also something "cap" something or other.Well 2 problems that are very very common, the plugs, and also the cords that go onto the plugs (Bougi Cords) that should have been the first test as its a miss fire so they should check the plugs if the were wet or just in good shaped, and then the bougi cords as they get old and brittle in places not seen to the eye. Hope it helps if you still struggling PM me if your around JHB can see if i cannot come through over the weekend.
They have diagnostic tools these days so they dont waste time testing every single component.
If you would like me to have a look at your car I can. Fixed a mates car after half a dozen workshops could not get it right.
PM me.
Distributor cap just fyi. Causes crap if water gets in.There is also something "cap" something or other.
It only really comes into play when starting the car.
Rather give me a broken PC. I can fix that! The car is the mechanics problem!![]()
2) Try pumping your accelerator 3 times in the morning before you start the engine. My uncle used to do this as "his fuel pump was lazy"
The head technician that's working on my car apparently came from VW...
Weird thing is, it can happen during the day as well, after leaving it in the hot sun for an hour or so, so can't understand how that can be battery-related?
Could be the voltage regulator overheating.
So not directly the battery, but the electric system feeding through incorrect voltage.
Used to happen often on an old bike of mine.
Never thought of that, strangely enough it could also be the negative cable going to the battery. I had that replaced at GM on my Cruze a year ago, it was giving odd symptoms. GM flashed firmware and replaced various things, though I kept telling them, the negative cable is probably the problem, there was even a recall on that. Eventually it was resolved and one of the symptoms was difficulty starting.
