chopsky
Hey guys
So for a while now, our VW Polo has experienced issues starting first thing in the morning, or when it's left outside on a very hot day.
Usually end up turning the key +-3 times before it starts. Recently, it's also started jerking a bit in the beginning (as if its misfiring), but only for the first 20 seconds or so. After that, the jerking ends and it drives normally.
I took it into Autoworks. They ran a bunch of tests on the car and determined that the battery was very low, so they replaced that.
Fetched the car, and the following morning, same thing happened.
Took it back to Autoworks, where they ran a bunch more tests on the car. Called me later in the day to tell me they couldn't determine what was causing the issue, especially since the problem happens very intemittently. They kept the car for another 24 hours and ran more tests. Eventually they called me to tell me they found a crack in the exhaust manifold and are sure that's causing the issue.
Went to collect the car this morning. R4,500 later, the same thing just happened!
Would any of you knowledge folk happen to know what might be causing this?
Am going to take it back to them first thing in the morning, but little hope they'll know what to do...
Thanks!
Thanks!
