Case USB3 Internal connector to USB2 on MB
dyanamo
Cape Town - Strand
Hi guys.
I would like to know if any of you know of a online store that sells the USB3 female plug to USB2 male plug locally.
In other words I need my USB3 header from my case to connect to my MB's USB2 internal header via means of a adapter. I Just want the 2 case USB3 ports usable by normal USB2.
Unfortunately I cant use a PCI-e card to get USB3 as I only have one available and its going to be for a wireless n card.
This is what I am after locally: http://www.ple.com.au/ViewItem.aspx?InventoryItemId=608660
If this is the correct product then this is probably your cheapest option (search there may be cheaper/longer options) ...
http://dx.com/p/usb-3-0-20-pin-male...31?rt=1&p=2&m=3&r=2&k=1&t=1&s=155217&u=169231
http://dx.com/p/usb-2-0-9pin-male-to-usb-3-0-20pin-female-adapter-cable-black-8cm-155217?rt=1
I have only seen these products available locally ...
http://www.rebeltech.co.za/index.php?main_page=product_info&cPath=76&products_id=4922
http://www.pricecheck.co.za/search/?search=USB+3.0+header&bcid=974
You could easily make up the cable if you have a soldering iron but you need to measure the headers very carefully as they come in both 2.54mm and 2.0mm pitches. You can purchase the headers from Mantech, Rabtron etc. You would need to take along a clear picture of the cable to get the correct USB 3.0 box header.
Some ideas ...
http://www.mantech.co.za/ProductInfo.aspx?Item=72M1240
http://www.mantech.co.za/ProductInfo.aspx?Item=14M8873
http://www.mantech.co.za/ProductInfo.aspx?Item=978-9685
http://www.mantech.co.za/datasheets/products/ME249-241.pdf
http://www.mantech.co.za/datasheets/products/ME249-246.pdf
Does deal extreme ship to South Africa at no cost? At the payments page and its not charging me for shipping. If this is the case then wow I have found my new favorite store.
Anyone have any idea on custom charges for a $3.60 item?
