Probably future proofing?
Hi, i want two replace for two reasons, firstly i want to up my speed to 200 mbps and cat 5 only goes up to 100 mbps and also I transfer over lan to a network drive, and want faster transfer speeds.Cat 5e cabling? Why exactly do you want to replace it?
Cat5e is gigabit.Hi, i want two replace for two reasons, firstly i want to up my speed to 200 mbps and cat 5 only goes up to 100 mbps and also I transfer over lan to a network drive, and want faster transfer speeds.
Do you have Cat5 or Cat5e cabling ATM ? There in lies the big difference here...Hi, i want two replace for two reasons, firstly i want to up my speed to 200 mbps and cat 5 only goes up to 100 mbps and also I transfer over lan to a network drive, and want faster transfer speeds.
Brilliant, thanks so much!!It's true not all cables are made equal, in my experience with this topic try and go and go with a reasonable brand, something like LinkBasic will produce consistent results, also make sure you get solid copper cabling, sometimes to save money suppliers will sell aluminium coated with copper which tends to break more easily.
In my opinion, worth it to have a sturdy cable network in place ;-)
I buy ALL my cable from Scoop...for myself and big projects. This one is a bit overkill as it is suitable for outside use as well, hence UV protected.
Why ???Cat 5 is still available today
Thanks, will make sure i do get the STP plugs as wellWhy shielded?
Linkbasic 100M Box Cat6 Solid UTP Cable | Network Accessories | Accessories | Accessories | Wifi & Networking | Electronics & Computers | Makro Online Site
Linkbasic's UTP-6100 is a 4 pair solid copper Category 6 100m Grey Ethernet Cable supplied in a 100m box. Specifications AWG Rating: 23 Cable Length: 100m Colour: Grey Conductor Dimensions: 0.565mm Construction: UTP - Solid Bare Copper Cross Filter: Yes ESD Drain Wire: None Number of Pairs: 4...www.makro.co.za
Very few applications require shielded cable and it's a bugger to work with sometimes. The UV protection is good for outdoors but unnecessary for indoors or in trunking.
Are you getting STP plugs and boxes as well then?
Correction, Cat 5e is rated at 1gig.Hi, i want two replace for two reasons, firstly i want to up my speed to 200 mbps and cat 5 only goes up to 100 mbps and also I transfer over lan to a network drive, and want faster transfer speeds.
