CCA cable
kitkat+
Hi Guys
Anyone using CCA cable with voice installations ?
I am thinking of using it for a budget installation.
Kitty
Hi Guys
Kitty
Would not advice that, you will run into problems at some point.
Go google on why not to use CCA cables ever.
Cost of CCA cable: 50% saving or more.
Cost of CCA cables including installation cost: 20% saving.
Long term - no saving.
During my last network installation technician made a mistake cutting 25m long cable short. It was a final part. The 305m box I bought myself in Rectron is finished. He has offered to use supplied by his employer (Telkom) CCA cable. OK in emergency. The cable lost a sync @1Gbps after few hours, dropping to 100Mbps and Ubiqiiti PoE AP was hanging, it required frequent restarts, few times a week. Replacing plugs didn't help.
