Cell C roaming On Vodacom wont connect
tiger001
My next door neighbor is having a problem login on his modem keep diverting to Vodacom roaming but wont make connection keeps giving an error code 264 on a Huawei B593 router Cell C signal very poor -110 dBm
Any help will be greatly appreciated thanks in advance
Hi tiger001
Please PM the number in question as well as your neighbor's contact number, we'll get in touch with them to assist.
Regards
Cell C | MM
Just tested with Huawei E173 modem and a Giga 200 cell C sim of my own which I cant use because of the poor signal -110 dBm at best
The modem does not detect Cell C but Vodacom Roaming signal strenth -63 dBm but wont connect to the Vodacom network.Seems the CellC data roaming agreement is not working in the Stilfontein area
Tested over the week end Cell C prepaid data connects to Vodacom. I don't know what has hapened at Cell C but I cant believe the speed I am getting from my Giga 200
Download Speed: 11008 kbps (1376 KB/sec transfer rate)
Upload Speed: 1687 kbps (210.9 KB/sec transfer rate)
Latency: 56 ms
Jitter: 6 ms
2015/07/20, 4:12:20 PM
I could never get more than 1mbs in the past ..you just got you old customer back
Thank you Cell C keep up the good work
