Cell c wireless dongle
UNarmed
I bought this cell c wireless dongle thing about 4 months ago. I am finding it impossible to work with. The line cuts out every couple of minutes! I have even resorted to watching movies on the side while browsing because it is that inconsistent. I live in the middle of ct so i dont think the reception is a problem. Does anyone have any ideas about how i can fix this problem?
might be usb-port related. Are you using a desktop or a laptop?
have you tried using different usb ports?
I'm looking for an adapter cable which will allow the dongle to get juice from 2 usb ports instead of just 1.
I have tried it on both a desktop and a netbook and each time the result was the same. Dont get me wrong when it works its fast, like +-80kbps but the problem is that it hardly works. it just keeps cutting out constantly and dropping the line.
Good Day UNarmed
Please can you PM your details and ill look in to it ASAP
Regards
~AM~
wireless dongle?!?! Are you referring to the D105 or MyZone router?
