CellC 3G data speed
nani2ratna
Hi guys,
Anybody using CellC 3G for skype calls or voip calls.
I bought a cellc(Hello mobile) sim and recharged with 100mb, the speed is very bad, Skype calls are not gud,
Is cellc gonna improve their network in near future???
If yes, then I want to port my number to cellc
Most mobile connections suffer from poor latency - compared to adsl.
The quality of Skype calls will also be dependant on time of day, ie network congestion and use, also where your tower is located.
Hi guys,
i have no problems with skype on cellc 3G, no glitches at all.
I also have no problems with voice or video calls via Skype, I suppose it all depends on your location and signal quality
