Charging my UPS
dawie54
Hi
Just bought an UPS, should I charge it before using??
Yes you should, just plug it into a plug for about 6-8 hours, do not connect it with the pc yet ;)
Read the manual. I don't know of a UPS that needs to be charged before plugging your pc into it. Plug in and use... :)
I did but it says nothing about recharging or charging before use. Just want to make sure to optimize my UPS battery's life.
