axxis uncapped express
Yes, that is the cheapest. I have been using the OpenWeb Uncapped Express for R1299.99 which claims to be an "unshaped" option. Dunno if there is really much difference. I have yet to try the Axxess option, but I should just to see if it gives me the same speeds. I can usually grab 800 Gb or more in a month. About 15 to 18 overnights and about 80 Gb on weekends.
and how much do you invest into harddrives?![]()
Lol Garyvdh, why pay the extra R300?
Because I started with OpenWeb a few months before Axxess released their product... and I am not sure that Axxess' speeds are much better than OpenWebs. The OpenWeb product is supposed to be unshaped and the Axxess is shaped. But I am willing to give the Axxess one a try next month and will report my experience.
Guys does the R999 EXCLUDE your ADSL 4meg line rental??
Yes it does... unfortunately.
The Telkom charges are on top of this, as is your own router cost.
How much is the line rental if you have an analog line? (4Mbps)?
Can you do that as well?
Which router do you folks recommend?
