Cheese: vertical or horizontal
Azbubu
Kapkaupunki
It's a debate that's raged on for centuries, almost as old as the earth itself (6000years old). Is cheese more suited to a vertical or horizontal alignment on the breadular plane? The world's greatest mathematicians have been unable to provide the theorems and formulas to solve this most pertinent dilemma of our times.
Cheese : vertical or horizontal.
Grated...
Or just slice one thick slab of cheese.
Cheese & bread should always be eaten in the form of a toasted sandwich - then the cheese is everywhere.
There are basically two considerations when making a cheese sandwich that will satisfy..
Coverage and overlap.
Coverage is the ratio of unexposed vs exposed bread, and overlap is the percentage of double layering needed to cover areas exposed by uneven cheese coverage. Coverage should be maximised and overlap minimised (for sandwiches within the ISO9002 specification, what you do with non-standard sandwiches is of course entirely your own business).
Thus, horisontal or vertical layering by itself makes no difference to the ultimate value of the sandwich except that the pattern employed should achieve the desired coverage with minimal overlap & wastage. Note that my canine of the sausage persuation disagrees entirely with this postualate as she is usually the sole beneficiary of the offcut process, but usually I find the perfect orientation of the cheese to be entirely dependent on the shape of the specific cheese & bread under consideration.
If longer, thinner vertical strips will achieve better coverage than shorter, thicker horisontal strips then so be it. Sometimes diagonal patterns cover the bread better, but might require lots of smaller cuts to optimise overlap (that gets my dog excited). The aim remains to achieve optimal coverage & minimal overlap within the parameters of the size & shape of the bread & cheese.
Overhang, crust disposal and the practice of simply folding a slice of bread around a block of cheese before chomping down is considered out of scope for this discussion.
The smell of cheese hits my nostrils horizontally but enters vertically, perhaps consider the diagonal option?
