Cleaning Viewfinder / focus screen
greg_SA
Durbanville
Hi,
Just thought I'd post my recent experience here...
I recently noticed a big mark through the viewfinder on my Nikon D40. It was first a very small black smear (minute)... but without changing lenses or anything, it turned into a big smear :( After some careful looking through the view finder, I saw that it was actually on the focus screen. I did some searches about cleaning the focus screen, and most of the posts/articles I found say "don't do it", "send it to Nikon" or "the focus screen is very delicate and will scratch extremely easily - don't touch". This info worried me and I considered sending it to Nikon (but this will cost $$$ and I'll be without my camera for a while).
I eventually built up the nerve to remove the focus screen as shown on a you tube video and another website:
http://deanmalandris.com/D70_technical/Cleaning the focusing screen/
I washed the focus screen with dish washing soap and water, but the mark didn't budge (so it wasn't dust or oil). I then used some isopropyl alcohol to wash the screen, and that slowly dissolved the mark - I think it was glue of some sort.
I re-fitted the screen, and it looks good :) So if anyone ever needs to clean the foucs screen, it can be done... just be careful - the screen is plastic, so never rub it with anything dry... always wash it with liquid and something non abrasive (I used a q-tip and my finger tips). Also make sure your hands are very clean, so that you don;t get any oily residue on the screen.
Maybe this will come in hand for someone :)
Cheers
Greg
Brave person. I think I'd pay someone to clean sensors and focus screens TBH. I'm just too clumsy when it comes to the serious stuff
I'm happy to yank out the focus screen on my 50D. It is interchangeable, and I changed it for a slightly more matted one, so I got the proper tool too (and a backup screen).
What I'm puzzled was that I appeared to have foreign objects inside my 40D's viewfinder. Not sure what they were or how they got in there.
