ClearlineIS Fibre
miyagi
Hi all,
So there has been people installing fibre in my are and I stopped to ask them who they are and they said they are Clearline. Now, searching through various ISPs, I can't seem to find anybody using clearline.
If any body knows who they are or what they do then please share some insight. Are they like a backbone fibre company or can you use them with an ISP?
Regards,
Liam
Clearline is a fibre contractor. They usually do work for DFA or the likes of the cellphone networks. Usually not fibre to the home.
ClearlineIS is a fibre contractor like Paul said that do work on behalf of DFA. They also did the majority of the fibre roll out in LHP in Bloem for the complexes here.
Go to https://signup.sadv.co.za/ and search for your address there. Chances are good that you'll be covered or have coverage through them :)
Thank you. Although, looking at that site it does not show the road they are working on as a covered area.
