klasvaakie
- Oct 26, 2008
Ok guys, Stay with me on this Thread... So Black Ops has just been released. I was able to get my PS3 copy last night at midnight release and waited for my beloved PC copy to arrive today.
Thankfully it arrived! Therefore, it's time to install.
Once it was installed, I was checking the console had been enabled etc. and started my own private server, turning on my FPS counter and whatnot.
I find that I'm getting 30 FPS, WOW, WAIT, WHAT? 30 FPS!
Before you ask, I have:
Q6600 @ 2,4Ghz Quad Core
3GB RAM
ATI 5850 with 10.10 Catalyst drivers.
Win 7 Ultimate 32bit.
650w Corsair PSU
Now I run CoD4 @ 252 / 333 FPS Constantly without any problem on a FPS cfg, without one I still get 160 FPS or so.
On WaW I get 125 / 250 FPS with a nice config.
So all you people who are having with Issues with Black Ops FPS.
I have found the problem, turns out the Game engine hasn't been worked out to optimize at it's best on each computer, so what exactly's wrong?
It turns out your CPU / Processor is taking all the power and it's getting leaked rather than going to your GPU / Graphics card.
So the fix turns out to be fairly simple... a FPS config! Who would of Guessed?!
I then decided to download Stevy's famous config... It worked!
Remember with stock settings and lowering things down graphically, I still hit 30FPS, now with Stevy's cfg, I hit 80+ FPS constant!
Instructions:
Download the file here http://www.fnatic.com/downloads/481/Stevy-config.html and unrar it to your desktop
Find your Steam folder ( C:\Program Files\Steam)
Then Steam Apps folder > Common > Call of Duty Black Ops > Main Folder ( C:\Program Files\Steam\SteamApps\common\call of duty black ops\main )
Once in this folder "Main", drag or copy / paste the config inside.
Start up Black Ops, Say no to the new pop ups and test it out.
NOTE: You may have to reset your player controls to default or to your liking.
For those of you luckey biatches that gets to play
