COD4 or BioShock?
Bona Botse
A little insight goes a long way
Here
i'm now in a position to buy two new x360 games, and one of them HAS to be Mass Effect, but i cant decide on the other... so should i get Call Of Duty 4 or BioShock?
depends if you're going to play mulitplayer or not. If no, then Bioshock.
CoD4 is awesome, but a bit short from what I hear. BioSchock is screwed up, but awesome none the less...
Do you like multiplayer or single player more?
If you enjoy multiplayer and are on Live then get COD4....
COD4's single player is also brilliant but a lot shorter than the brilliant Bioshock single player..
Bioshock is a slower and more thinking type of FPS as well
yeah i will be playing online a lot. so cod4 it is then. any of u guys have mass effect?
Not Bioshock
I am getting COD 4 in 10 minutes, but don't get Bioshock, its more like boringshock
CoD4 hands down for online.
It's the new "Gears of War", sorry Halo, you're awesome, but just a bit too mainstream ;) .
CoD4 is brilliant, if youre even considering playing on live CoD4 is the way to go
I'm buying Call of Duty 4 today when work finishes. Just a quick walk to the waterfront :)
