Compact Flash Card reader
bwana
MyBroadband
Super Moderator
Plz
I've often wondered . . . is there any advantage to using an external card reader instead of attaching the camera directly to my laptop?
Well with a card reader you open up the option to use memory cards of different types from different devices and now that you get these 1000 in 1 readers for dirt cheap no reason not to get one, and also think theres a bit of a speed benefit like Syndyre said.
Depends on the camera model. Some are faster than other when connected directly to the pc. Still its so cheap to buy a card reader, buy one and try.
Well the camera doesn't seem slow - even with those 10mb raw files coming off it - but you're right, seeing as the readers are pretty cheap why not. :)
It does mean I can copy off one card and shoot with another if the need arises.
You guys have so much money it's not even funny. I wonder if I'd be able to start a thread like this one day? :p LOL!
I consulted the Magic 8 Ball on your behalf - the answer was a solid "Yes" :)
BTW - the card reader I saw was about r150 - hope you can start a more impressive thread than this :D
Thanks for the edit, I was just about to say that you always know how to "shatter" my heart ;)
Maybe dude, I'll start a thread and say I'm buying telscum or something :p ;) :D
It doesn't use up your camera's batteries?
I'm not sure what the useage is like for transferring files, or does the USB handle that? I heard abot it from someone, not really sure..
EDIT: To answer my own question: "It uses power from your computer so you save camera batteries." From some article about card readers.
