hi all, i have question which i hope someone can help me with. to run solar panels at 24volt you need to connect 2x 12volt panels in series. when one does this, the voltage double to 24, but the amperage stays the same, assuming you are using 2x 75watt panels, that each put out 4 amps you would get a 24volt system that puts out 4 amps. my question is what happens to the amperage if you connect two panels of diffirent sizes together?ie a panel putting out 1 amp with a panel that puts out 4 amp?any info will be appreciated, thanks greg
