Krypt0n1te
HI Guys - - - - -This is the most bizarre thing ever---especially the Modem part.
Let the troubleshooting begin
Network: VodaCom
Phone:Nokia 5800.....but please help it might be network or APN setting which should be same for all Symbian's
OS: Windows 7 32 and 64 bit Ultimate
I know there were issues with the initial Nokia 5800's, i think I might have the same problem now, however it did work before.
My 3G takes about 1-2 minutes to connect...in full 3.5g area, so long that Ovi Maps time out. Usually it connected in less than 5 secs.
I have tested 2 SIM Cards in phone, no luck, only after about 2mins I get connected and then I can use it.
Tested in different phone both work.
PHONE Issue Recap
3G work on phone, but takes VERY long to connect.
PHONE as modem Issue
When I use my phone as modem, AGAIN after 2 mins it connects, BUT NO ACCESS to internet, cant browse at all.
Now the strange part....
If i connect to PC via GPRS (gsm) it connects immediately (less than 5secs) and I can browse...if I then change Network to 3G (Dual Mode) whilst connection is active, it switches to 3G and I can browse at full 3G speeds.
WHAT IS UP WITH THAT??
I'ts only the initial connection to 3G that seems to be messed up. Any ideas???
Please help me!
Network: VodaCom
PHONE Issue Recap
Please help me!
