Connection Help Needed
Icemanbrfc
Hi Guys
Need some help with a fire Tv wired setup.
It worked fine, but all of a sudden I get no connection.
Below is the configuration settings, but can anybody point out if these are correct. My isp is Afrihost
Gateway and IP address is wrong.
IP adress would the address allocated by your ADSL router if DHCP enable or staic in your network ip range. Either 192.168.x.x or 10.0.x.x.
Gateway address should be the internal IP address of your ADSL router.
I suspect the problem lies with you ADSL router and not this device
What router are you using?
Almost looks like apipa address, bit it's not
thanks guys and to Johnatan on here. managed to get it sorted. IT Cynic, yeh that seems to have been the issue. I think i i had the Gateway wrong
Imran, using the Huawei router supplied by Telkom
