Connection Issues
Crabby
CT
Hi all
Anyone got some suggestions as to what to do to log into WoW ?
Up until about 2 weeks ago I was logging on and playing fine.
Since then I cannot connect to the WoW network or the news page if I go through the launcher.
The rest of the internet works fine and all my other online games still work.
Ideas ?
Ping and Tracert is screwed
Code:
E:\Documents and Settings\TF>ping us.version.worldofwarcraft.com
Pinging us.version.worldofwarcraft.com [206.16.22.126] with 32 bytes of data:
Request timed out.
Request timed out.
Ping statistics for 206.16.22.126:
    Packets: Sent = 2, Received = 0, Lost = 2 (100% loss),
Control-C
^C
E:\Documents and Settings\TF>tracert us.version.worldofwarcraft.com
Tracing route to us.version.worldofwarcraft.com [206.16.22.126]
over a maximum of 30 hops:
  1     *       <1 ms    <1 ms  10.0.0.2
  2     *       22 ms    22 ms  dsl-145-192-01.telkomadsl.co.za [165.145.192.1]
  3     *        *        *     Request timed out.
  4     *        *        *     Request timed out.
  5     *       40 ms    43 ms  196.43.33.2
  6    42 ms    42 ms    43 ms  196.43.33.5
  7   394 ms   391 ms   413 ms  ash-ip-dir-equinix-pos-4-0.telkom-ipnet.co.za [
96.43.18.30]
  8     *      385 ms   387 ms  12.117.208.5
  9   430 ms   431 ms   430 ms  tbr1.wswdc.ip.att.net [12.122.80.194]
 10   523 ms   537 ms   462 ms  cr2.wswdc.ip.att.net [12.122.16.5]
 11     *      447 ms   449 ms  cr1.attga.ip.att.net [12.122.1.173]
 12   391 ms   390 ms   390 ms  cr2.dlstx.ip.att.net [12.122.28.174]
 13   450 ms   450 ms   450 ms  tbr2.dlstx.ip.att.net [12.122.18.206]
 14   427 ms   426 ms   428 ms  br2.dlstx.ip.att.net [12.123.16.213]
 15   428 ms   427 ms   427 ms  mdf1-gsr12-1-pos-7-0.dal1.attens.net [12.122.25
.82]
 16   437 ms   436 ms   433 ms  mdf002fbi8ks0002-eth-2-4.dal1.attens.net [63.24
.192.158]
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23     *        *        *     Request timed out.
 24     *        *        *     Request timed out.
 25     *        *        *     Request timed out.
 26     *        *        *     Request timed out.
 27     *        *        *     Request timed out.
 28     *        *        *     Request timed out.
 29     *        *
Could very well be your firewall, try disabling it. But we need to know what programs have you installed recently. Any updates done? what anti-virus you using. What ISP you using.
I had the same problem yesterday after installing the new patch.All i did was restart my pc and i could log then i disabled the addons i was using ...i suspect that was the proplem..the addons.try deleting them out of your ui folder and see if that works..otherwise reinstall or get a copy from a friend
Guess he sorted the issue or have lost his internet completely now ;)
