Reign
- Apr 20, 2009
Hi,
Im having this issue where my connection freezes meaning my online game will freeze, twitch stream im watching will freeze then resume like 5 seconds later and latency has spiked to 1700ms in game then 2 seconds later its back to 190ms. Been happening quite frequently since last week tuesday. Here is my line stats.
Router Stats:
ADSL Link Downstream Upstream
Connection Speed 12476 kbps 1023 kbps
Line Attenuation 8.0 db 5.0 db
Noise Margin 16.7 db 8.5 db
Ping:
ping bras.afrihost.com
Pinging bras.afrihost.com [155.239.255.250] with 32 bytes of data:
Reply from 155.239.255.250: bytes=32 time=20ms TTL=63
Reply from 155.239.255.250: bytes=32 time=21ms TTL=63
Reply from 155.239.255.250: bytes=32 time=19ms TTL=63
Ping statistics for 155.239.255.250:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 19ms, Maximum = 21ms, Average = 20ms
Zertop Stats:
Zertop's LineTool Results
Date/Time: Wed Aug 22 12:18:48 CAT 2018
Basic Report:
Your packet loss was 0%.
Your average ping was 23ms.
Your maximum ping was 49ms.
Looking at your average ping, your line seems to be running perfectly.
Looking at your maximum ping, however, it seems as though there could be a slight intermittent issue on the line. If required, please post the results to a forum post.
Detailed Report:
Speedtest.net:
Mybroadband Speedtest:
https://speedtest.mybroadband.co.za/result/7951366
Ping: 44ms
Download: 9.5Mbps
Upload: 0.82Mbps
any ideas what could cause this as its really becoming a pain.....
Router Stats:
Ping:
Zertop Stats:
Basic Report:
Detailed Report:
Code:
Pinging 155.239.255.250 with 32 bytes of data:
Reply from 155.239.255.250: bytes=32 time=49ms TTL=63
Reply from 155.239.255.250: bytes=32 time=42ms TTL=63
Reply from 155.239.255.250: bytes=32 time=36ms TTL=63
Reply from 155.239.255.250: bytes=32 time=47ms TTL=63
Packets: Sent = 30, Received = 30, Lost = 0 (0% loss),
Minimum = 19ms, Maximum = 49ms, Average = 23ms
Speedtest.net:
Ping: 44ms
Download: 9.5Mbps
Upload: 0.82Mbps
