"Connection partially encrypted"?
stevovo
Pretoria
Good day
Does anyone know how I can find out what is and is not encrypted on a specific website?
The first few pages (as well as the login page) shows that it is fully encrypted, but after that, it mostly says "connection partially encrypted".
Also, if a page is encrypted and you download a file, with the file be delivered to your pc using ssl as well?
many sites that are secured somtimes have links or stuff loaded from an outside source which makes it say "connection partially encrypted"
A typical example is when they add google analytical ...
firefox view page info, then media tab shows everything thats there and the source.
hmmm everything under the media tab does begin with https://website.com/.
There's no other websites listed there or anything that starts with http://
Any other ideas how I could check?
And the question about the file downloading? Does anyone know if that goes over secure as well?
