Continuous ink suppy system
ugan.git
Greeting All,
I need advice on a good continuous ink supply system for HP and Epson. I have these printers and im tired of spending R400 after doing a nozzle clean.
I see that ebay has a few and there are a few companies in JHB that supply them.
Any advice/comments will be most appreciated. What would be a good CISS supplier (local is lekker) and which is a good brand.
Thanks.
Le'git
Greeting All,
Thanks.
Le'git
Before wasting too much time and money do some research on the Epson L800. Build in Ciss and apparently very cost effective. Six inks for excelet photo's.
The average CISS is around R1000 which is not bad considering you have a printer. The L800 is a brilliant printer but at R4500 its a bit steep for home use.
I have seen those CISS systems in the link below but I don't have any experience with using them myself. I have seen some good specials from time to time at Incredible Connection on those Epson CISS printers that were mentioned above. Just check for printers on www.guzzle.co.za.
http://www.akita.co.za/ciss/default.htm
There are Epson printers that are sold factory-standard with the "expanded tank system". You buy the ink by the bottle to refill.
On my mobile with edge(current location) so cannot link as Epson's site won't load (graphic rich).
Hi gents,
Thanks for the info. I will make contact with these guys. Is there anyone who has installed these systems themselves. I would like to know the reliability and quality of the print and the CISS compared to normal cartiges.
Thanks,
Le' git
