I'd like to start off small and then grow it as I go along. I'd like to implement the smart lights as a start and then also integrate the current entertainment system with the automation.How big do you want to go?
A couple of us on here run Home Assistant but there is some learning up front.
Mine manages 2x geysers, sunsynk inverter, some lights, electric blankets in winter and I need to add a new aircon still.
The Home Assistant Green is nice. What we find works well is a "refurbed" Core i3 or i5 Lenovo or Dell Mini with SSD. It is small, and you can pick them up at a pretty good price. The extra horsepower helps when your instance becomes a bit bigger, and you are running many automations or Node-Red flows.I'd like to start off small and then grow it as I go along. I'd like to implement the smart lights as a start and then also integrate the current entertainment system with the automation.
It really depends on what you want to do but a centralized orchestration server is great and Home Assistant has already been mentioned which runs on pretty much anything.I'd like to start off small and then grow it as I go along. I'd like to implement the smart lights as a start and then also integrate the current entertainment system with the automation.
