satanboy
Psychonaut seven
How do you tell how full or empty your gas cilinder is?
Weigh it when full and empty.
Cool trick to check level:
Get a cup of hot water and trickle it down the side. Now run your finger from the top down along the wet surface until you reach the spot where the water is suddenly cooler.
That's roughly where the current level of gas is.
What is the empty weight of bottles?
All bottles will vary depending on their size, etc. The weight written on the metal disc on the shroud is the weight of the empty cylinder.
How can I monitor how much gas is left in a cylinder?
...the empty tare weight can be found on a metal disc on the shroud, this gives the weight of the cylinder
How full is a Calor gas cylinder in a full condition, in percentage terms?
All cylinders are 80-87% full as space needs to be left for the expansion of liquid. The weight on the front of the cylinder is the total weight of gas in the bottle.
and then your cupboard is wet![]()
You should not have a gas cylinder in a cupboard - they should be installed outside. See http://saqccgas.co.za/?page_id=84
My gas installer guy told me that only gas cylinders over 9kg must be installed outside with the proper fixed lines and shutoffs and need a complience certificate. 9kg and smaller cylinders can be stored in a kitchen cupboard with flexible hose to the cooker. I hope he didn't lie to me.
dont matter how big ...little gas plus curtains and wood = beeeeeggg fire
1. Not more than 19kg LP Gas allowed within any building (including empty cylinders).
11. LP Gas cylinders required to be stored in a lockable cage or cupboard with adequate
ventilation.
