Coolermaster Aquagate Max Liquid Cooling
by: ettienem
Description: Specifications CPU Socket Intel Socket:LGA775AMD Socket:AM3 / AM2 / AM2 / 940 / 939 / 754CPU Support IntelCore 2 Extreme, Core 2 Quad, Core 2 Duo, Pentium Extreme, Pentium Dual-Core, Pentium D, Pentium 4, Celeron Dual-Core, Celeron D, CeleronAMDPhenom, Athlon 64 FX, Athlon 64 X2, Athlon X2, SempronSupport Watt 600 WWeight 1700 gQuick install connector 3/8 inch (9.5 mm)Water Block Dimensions 50 X 50 X 42.5 mmWater Block Material CopperRadiator Dimensions 300 x142 x 71 mmRadiator Material AluminumFan Type Green LED FanFan Dimension 120 x 120 x 25 mmFan Speed 850~2400 R.P.M.Fan Airflow 71.81 CFMFan Air Pressure 2.73 mmH2OBearing Type Rifle bearingFan Life Expectancy 40000 /hrsFan Noise Level (dB-A) 22 dBAFan Connector 4 pinFan Speed Adjustment PWMFan Rated Voltage 12 VFan Start Voltage 7 V (Max.)Fan Operating Voltage 10.8~13.2 VFan Rated Current 0.4 A ( Max.)Fan Input Power 4.8 WPump Dimensions 47 x 62 x 60 mmPump H-max 2 meterPump Q-max 450 L/H (Max. )Pump Bearing Type Ceramic BearingPump Life Expectancy 50,000 hoursPump Noise 23 dBAPump Rated Voltage 12 VPump Input Current 0.6 APump Power 6.5 WReservoir (Capacity) 340 mlReservoir Dimensions 122 x 89 x 74 mmTubing Material PVCCoolant color GreenCoolant Capacity 260 mlCoolant Main Material GlycolCoolant Freezing Point -10 degreeCoolant Life Expectancy 2 yearsTemp. Sensor Dimensions 98 x 20x 450 mm* Supplied accessories may differ by country or area. Please check with your local distributor for further details.Buyer to collect or pay shippingBuyer will need to get more coolantNew price from www.cyburia.co.za - R 2359http://www.coolermaster.com/product.php?category_id=3569&product_id=3855
by: ettienem
