SaiyanZ
So my PC shut down randomly a little while ago. Switched it back on and got a CPU fan error so I opened up the PC to check.
The fan doesn't spin anymore. I used a vacuum cleaner to blow out dust and there wasn't much so that isn't the issue. The fan spins freely and extremely fast when holding the vacuum over it whilst switched off. I then pulled out and reconnected the fan power connector. Still not spinning at all.
So I think my CPU fan is busted. The other fans in my case spin and I even tried connecting the CPU fan to one of the fan connectors for the case. Still nothing.
There was some lightning last night so maybe that could have done something. I used the PC for about 6 hours straight today with heavy gaming though until it switched off randomly.
Any other recommendations to try before I purchase another fan/cooler? This is the stock fan/cooler for the FX8350 CPU which I've been using for over 3 years.
