Resilience
Hey guys - So I'm getting a bit moedeloos here and thought I'd turn to the vets of MBB for help.
Background in a nutshell:
I have a 2750U, I'm on an uncapped axxess 4mb account. I lived close to an exchange now I live further away.
I have had intermittent internet before I moved away from the exchange but wasn't phased as much. just annoyed.
After moving my internet is now a lot worse but only after 6-7PM
When I say worse I mean speed tests time out, or I get Latency Error's on saix speed tests.
It's not always, and sometimes it happens in the mornings as well but definitely rarely and the speed improves to around 0.80 instead of the 3.8 that I usually get.
I have a neighbour who runs the same axxess uncapped account, to the same exchange, through the same telephone line, on the same line speed, and she gets full speeds almost always with no crawling. We live in someones yard and our routers are about 3 meters apart.
Problem:
My internet isn't always crap, telkom has come out once in 8 months of me staying here. Axxess keeps asking for screenshots of the guest account speed tests. I have supplied countless, saix and otherwise, my faults keep getting closed and nobody comes out. Spoke to a manager, he got telkom to come out, but I was on holiday (nobody told me they were coming or confirmed a time) and they came in the middle of the day, when the error doesn't occur. That was 2 months ago. I am still having internet problems.
I have been told its congestion, that i need to downgrade, yet on the property we stay, there is are 2 x 4mb users and 1 x 2mb user and I'm the only one with the problem
What I have done so far:
Updated firmware to latest, reduced HEC errors on the upload, check the cable for damage, replaced the filter, changed passwords on everything and made my wireless invisible, tried new LAN cables, monitored for clients that shouldn't be on, check my internet usage.
Below is my current stats:
Mode: ADSL_G.dmt
Type: ATM
Status: Up
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (0.1dB): 87 130
Attenuation (0.1dB): 480 270
Output Power (0.1dBm): 196 91
Attainable Rate (Kbps): 4864 896
Rate (Kbps): 4096 512
D (interleaver depth): 1 1
Delay (msec): 0.13 0.25
HEC Errors: 0 0
OCD Errors: 0 0
LCD Errors: 0 0
Total ES: 3 0
___________________________________________
(old)
If I mess with my filter by switching cables I get :
Downstream Upstream
SNR Margin (0.1dB): 69 140
Attenuation (0.1dB): 485 275
Output Power (0.1dBm): 196 100
Attainable Rate (Kbps): 4352 892
HEC Errors: 27 2937
OCD Errors: 0 0
LCD Errors: 0 0
Total ES: 3 0
(old)
If it gets severe I get:
Downstream Upstream
SNR Margin (0.1dB): 65 130
Output Power (0.1dBm): 188 91
Attainable Rate (Kbps): 3872 904
Rate (Kbps): 3840 512
HEC Errors: 9 2472
OCD Errors: 0 0
LCD Errors: 0 0
Total ES: 4 0
I really don't want to downgrade to a 2MB line as it just doesn't make sense to me as the best solution. There has to be something I'm missing http://mybroadband.co.za/vb/images/smilies/frown.gif
Problem:
Mode: ADSL_G.dmt
Type: ATM
Status: Up
Downstream Upstream
HEC Errors: 0 0
OCD Errors: 0 0
LCD Errors: 0 0
Total ES: 3 0
(old)
Downstream Upstream
HEC Errors: 27 2937
OCD Errors: 0 0
LCD Errors: 0 0
Total ES: 3 0
(old)
Downstream Upstream
HEC Errors: 9 2472
OCD Errors: 0 0
LCD Errors: 0 0
Total ES: 4 0
