creating an access point using 3g?
sh4rpz
Durban
Hi,
i have a netgear wireless router dg834gs and was just wondering if it was possible to use it as an access point along with my vodacom 3G card's internet access?
thanks
Hi,
thanks
Hi
You want to connect multiple pc`s to WIFI connection connected to the 3G network connected via a 3G datacard in the netgear?
Regards
VodacomData
Hi,
thanks
If you can get Internet connection sharing working on the PC with the 3G card and it's also on your wifi network then you should be able to use it. An easier solution is however something like the B970 router (3G, Wifi AP all in one).
Hi
Regards
VodacomData
something like that - i want to use my 3g internet access on my pc to be shared with my ps3 via the netgear wireless router.
i've got the ps3 to see the router. keep getting a DNS error.
Disable the DHCP service on your router, give it a static IP address in the 192.168.0.2 - 192.168.0.254 range (write this on a label and stick it on the router), enable Internet Connection Sharing for your 3G dial-up connection on your Windows box (it will become 192.168.0.1 and enable DHCP), reboot your PS3 and you should be done.
howsit ginggs! thanks for the reply. how exactly do i disable the DHCP service on the router? (i have a good but basic understanding of how to set up network, so please explain)
thanks again
