Curious - sleeving or fibre
george_vg
Just as a matter of interest...Is the rolls of "cable" you see all over the place the actual fibre optic cable or just a type of sleeve for it?
Looks like maybe about 20-30mm in diameter and all over next to highways mostly.
That's the duct. Must be buried first. Fibre will be hauled through afterwards.
I have seen two types... the larger sleeving usually green and ribbed ... about 20 cm wide and hollow is for Telkom wires I think.
The fibre is usually a solid cable about 5 cm wide. Comes in all kind of colours.
Green ribbed sleeving is usually Telkom, the Orange version is used by Neotel.
The actual fiber optic cable is between 10-20 in thickness, black or orange in colour.
What you saw were the sleeves. Orange in colour and normally rolled up.:D
