nakedpeanut
Nice thanks for the info, Never heard of the vinegar before. Where are you getting your parts from?
Reason why i went the CM is they have a suitable rpm/db ratio as well as cfm/db.. I don't wanna go over 25db rating 30 is pushing it.
Oh an they blue
I'm also thinking of building a black shroud for the rad.
The order will only be placed on the 6th as I'm ordering with a group. So got time to change. Keep on the suggestions![]()
so if flow velocity increase so does flow volume to the same extent but there will be a drop in static pressure?Because air flow velocity is directly proportional to air flow volume and proportional to the static pressure drop
