Hi all,
I'm a newb here so apologies if I'm asking stupid questions...
I've had a Cybersmart 384kbps account for just over a year. It used to work like this: I plug the router in, the ADSL link light blinks for about 30 seconds, and once it's solid, the internet works. Now, I went to a LAN earlier this year (about August/September) which totally screwed my PC up (I had to reformat and reinstall Windows), and since then I've had weird issues with my internet connection.
Part of my recovery included rebooting the router, and I think this is where everything started going wrong. I'm suspecting that I haven't entered all of the settings correctly after the reboot, although I've done everything as per the 'General ADSL Router Setup' instructions on Cybersmart's website (I have a bog standard Cybersmart issued Conexant GS8100 Vulcan / Mecer 4 port ADSL router). Anyway, after the reboot, I entered my default gateway address in Firefox and I set my router up as per Cybersmart's instructions. It then reported a 'Link Down' error, stating 'Auth Failed'. I phoned them and they informed me that there is a port error on their side, and they fixed it (I've had this happening randomly a few times in the past couple of weeks). The connection then worked again.
Now, while it does work (sort of), I'm experiencing the following:
- When I plug the router in and the ADSL link light goes solid, I have to wait about 2 extra minutes before I can use the internet. I checked the router setup and the PPP screen is showing 'DHCP' under 'Oper Status' while I'm waiting for the internet to start working. I never used to wait for an address to be acquired from the DHCP server - once the link light was solid, the job was done.
- When the internet finally starts working, it works for about 10 minutes (this varies) and then the connection just goes 'dead' - not like the lights are going off, the connection just isn't doing anything - I can see that packets are being sent, but none received. After about 5 minutes (this also varies) the connection suddenly works again (for about 10 minutes), etc etc.
I phoned Cybersmart about this, and the guy said he doesn't really know what's wrong, but he did give me DNS addresses which I entered on the router setup and in the Control Panel/TCP-IP settings screen (thus I'm obtaining an IP address automatically, but not a DNS address). It doesn't seem to make a difference at all though.
Not sure if this is the problem, but on the router setup screen, under the 'Routing' menu, there are 9 different routes between which the router hops. Shouldn't there only be one destination address?
If anyone has any ideas whatsoever as to what my problem could be, any help would be greatly appreciated.
Thanks in advance
Thanks in advance
