reactor_sa
Hi, my car was going well before its 135,000km service last week. I took it to the Ford dealership where the car was purchased years ago as I usually do.
Between the dealer services I change the oil myself with quality 10W40, I know ford generally use **** castor gtx 20W50.
Anyway the problem is I checked the oil yesterday (week after the service) because the invoice said they charged me for 4.5L of castrol gtx and I know it usually takes 5L to the halfway mark on the dip stick. Also the car is feeling much more reluctant and longer to warmup properly.
To my shock I see they have overfilled to about 1CM above the max mark on the dip stick. How bad is this on a turbo diesel and what should I do?? I'm worried the oil may foam and cause loss of oil pressure and the turbo will probably be the first to go.
This is the last time I go to a dealership to pay R1700 for too much **** quality oil and a stamp.
