Fazda
What would happen if you fill the oil till it overflows (i.e. cant accept any more) and then drove it like you stole it?
The motor would pack up - plain and simple.
Probably a line down the dipstick tube attached to a vacuum pump.
Many dealers do oil changes that way these days.
Yea, about R300 bucks at a car parts shop last time I checked, you get the kits with the oil filter wrench included a bit more pricey.
I checked the oil yesterday (week after the service) because the invoice said they charged me for 4.5L of castrol gtx and I know it usually takes 5L to the halfway mark on the dip stick.
To my shock I see they have overfilled to about 1CM above the max mark on the dip stick.
I know ford generally use **** castor gtx 20W50.
My scoob manual indicates 4.5L for a refill. I have put in 5L for the last 10 years. No issues. But this car has a windage tray and the sump can carry the extra oil. My Oil pressure gauge shows the same pressure with 4.5L or 5L (Mobil 1 15w50 PAO)
Correct - crankshaft pressure can become critical in an overfilled engine - High Blood Pressure for cars!
I only check my oil first thing in the morning, then I know that it's at the correct reading.
It is more critical on a car like a Subaru, however, as the Boxer engine, being flat, takes easily an hour for the oil to run back into the sump.
I had a friend completely bugger up his engine on his WRX when they first came to SA.
He was on a long trip and the oil light came on so he stopped and put oil in(3 pints) then 80km later it was still on and he put another 2 pints in, rinse repeat for a few pints and they way he drove it basically things broke badly.
Turns out it was a faulty oil sensor and he had put many more pints in than it needed.
Fortunately it didnt phase him much and he was a wealthy lad, he managed to source a 22B motor from a contact in Japan and his car was a monster after that.
some say...
too much oil puts pressure on seals etc..
You can supply your own oil at a service.
Most people would check the dipstick when filling up. As this allows you to determine the amount of oil to fill.
If anyone fills 2.5L of oil on one trip and does not figure out something is wrong.........
The idiot light is just that.
BTW if the oil pressure light comes on in subaru. The big end bearing is toast.
Hence the 4.5L they charged me for was obviously a lie.Hence ??????????
This. Done this before with VW. So instead of R1200 for ****ty oil and R500 for labour you get better oil for R400 and they just charge you R500 changing and for the stamp![]()
