Decoder not scanning
Drone
Banned
It's Saturday and I have the household on my back
After another loadshedding session the DSTV decoder doesn't scan anymore and I get the 8118 error. Naturally I Googlied the error and got here
http://www.e18error.com/dstv_8118_error_code.html
I've tried the
Flash erase 8118 and Manual upgrade steps and it wasn't successful
So next will be a possible Capacitator replacement
Where can I get hold of these?
Just have a feeling MultiChoice will tell me to replace the decoder when I MIGHT not need to.
Nope... That is the PSU problem...
Yip...just bought a new decoder for R500. I could have searched for those capacitors but the decoder was outdated anyway and with the new ones if you have another problem after a spike one only have to replace the external power supply.
come Monday I shall be searching for surge protectors for all my appliances
router also gone...luckily I had spare, but this is insane.
Any advise will be welcomed specifically with regard to how many is needed. For example if I have 5 appliances on a multiplug do I only need one for the multiplug and will it protect all those appliances or how does it work?
