Defy thermofan oven problem
Sonnetvzyl
I have a defy thermofan under counter oven. I take very good care of it. Lately the fan only comes on for a few minutes, it is very noisy, and then stops turning. The element works fine. Can anyone please help
Seems like the fan either needs to be serviced or replaced(more likely).
I'd guess the fan is packing up.
Try to phone the service department at Defy and see what they suggest. The should be able to tell you exactly what needs to be replaced and advise you on how to remove the faulty components. When I had problems with my Defy Washing Machine they were very helpful and even replaced a bearing for me for a nominal fee.
