Dirty Fuel Tank?
mouks
I'm no petrol head and need some advise:o. Can anyone tell me what the symptoms off a dirty fuel tank are. I'm currently fixing up a E36 318i BMW Dolphin Shape. Car idles fine but has trouble accelerating in first gear, slight jerks effect like it not getting petrol/power or something. Once it reaches optimal speed the car runs fine. I need a second opinion and don't want to be conned out of my money
Doubt its that.
It might be your fuel pump or MAF or even a dirty fuel filter that needs to be replaced.
Suggest you take it to a reputable BMW workshop for proper diagnostics.
Doubt its that.
Yeah, most likely the MAF or some other sensor. Also check the throttle body that the butterfly flap is not stuck. And stay away from BMW dealerships, they will rip you a new one.
There are probably more symptoms, but from my experience a dirty fuel tank will exhibit stuttering on acceleration when the tank nears empty.
yeah, meant to say reputable Independant BMW workshop, not the dealers themselves.
Its probably the MAF, but at +-R2700 a pop its best to get a proper diagnosis of the problem first.
Yeah those things are goddamn expensive :wtf: I paid R3k5 for mine.
When driving about 90 or 100kmph put your car into 1st & let the clutch out. That should clear it up.
Get the OBD plugged into by a BMW workshop (stealership or other) get a print out of the fault codes and work your way through those first.
Also check all vacuum hoses for leaks
You can get MAF cleaner from some part shops although they are normally reluctant to sell it to the public and will try sell you a new sensor at a retarded price.
Take it to Frank's Motors, Queens Park Road, Salt River. They fixed my pa's 318i after Auric Auto had quoted R9000 for a whole list of things. In the end he paid R1250 and only 1/3 of the items listed needed doing
MAF cleaner will not work if the MAF itself is faulty. I've used pure alcohol on mine for my previous car, and it worked.
Symptoms don't sound like fuel or Maf related... Does it also jerk/hesitate in higher gears?
No.. Also did a dino tune test they other day they did not give me the result just fix a one faulty pipe
UPDATE: ISSUE RESOLVED
SOLUTION: "iemand het vir my die kar se timing gestel"
