JerryMungo
- Jul 18, 2008
I'd like to make myself a decent solar charger for my tablet. I'd like to build it into an A4 sized folder. I'm thinking about 10 of these in parallel will give me around 800mA at peak which should be good for charging on the go.
http://www.dealextreme.com/p/0-44w-si-solar-cell-panel-5-5v-80ma-12988
So a Q for the electronics fundis - I assume I need more than just solar panels to do the charging - like something to regulate the output to some degree. I'm not sure if the tablet itself can handle the charge cut-out to prevent overcharging or if I need something like that on the panel side too?
Thanks in advance!
Thanks in advance!
